NorwayG60 0 Posted December 19, 2022 Hi. A question We had our Corrado G60 stored for like 15 years and have taken it out now :) I wonder how uniqe the ECU are becouse it has a trim chip inside but will make i original again. unfortunately we cant find the orignial chip so we have two option. 1. purchase a original chip and install it 2. purchase a simular original ECU and plug it in. will the mileage change if we put in and whole ECU or is the milage uniqe in the cluster? We don`t want to mess around with the milage on this becouse it is very low :) Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted December 20, 2022 19 hours ago, NorwayG60 said: Hi. A question We had our Corrado G60 stored for like 15 years and have taken it out now 🙂 I wonder how uniqe the ECU are becouse it has a trim chip inside but will make i original again. unfortunately we cant find the orignial chip so we have two option. 1. purchase a original chip and install it 2. purchase a simular original ECU and plug it in. will the mileage change if we put in and whole ECU or is the milage uniqe in the cluster? We don`t want to mess around with the milage on this becouse it is very low 🙂 hi, thanks for the post i would imagine purchasing an original ECU would be the best route if you want to keep it original & standard i believe the mileage is only recorded in the cluster & as such would not change with a replacement ECU pls do share some pics if you would like to Quote Share this post Link to post Share on other sites
