KarlosG60 2 Posted November 2, 2023 Some more pictures. Blue sensor water temp. Also I did Throttle connector (no pictures). Done: The working cave place: Next step will be check V at hall connector. If it's fixed I will then do a bit more wires and connectors (ISV, injectors, gauge water temp...), tidy and protect everything and go to next step, that will be to pull down oil sump, because I think something drop inside the other day. 🤦♂️ Even it's fixed or not I think I will replace hall sender, now it is outside the engine. Quote Share this post Link to post Share on other sites
KarlosG60 2 Posted November 2, 2023 WIRES & CONNECTORS. FIXING AND REPAIR Circuit component Original Wire color Original Section New wire color New wire section ECU Pin Bentley Connectivity and resistance are ok Empalme + cable nuevo completado Resistance value Status Date Notes Ignition Coil G 1.5 FALSE TRUE Y Ignition Coil BK 1.5 FALSE TRUE Y CO2 sensor connector BL/W 0.5 TRUE TRUE Y 29/10/2023 CO2 sensor connector BL 0.5 TRUE TRUE Y 29/10/2023 CO2 sensor connector BR/W 0.5 TRUE TRUE Y 29/10/2023 Throttle connector R/BL 0.5 R/W 1 11 FALSE TRUE Y Throttle connector BL/BK 0.5 W/BK 1 15 FALSE TRUE Y Throttle connector BR/W 0.5 no changed 1 6 FALSE TRUE Y 2/11/2023 Ground 94, In Digifant wiring harness Ground 94 to Co2 BR/W 0.5 6 FALSE TRUE Y 2/11/2023 In Digifant wiring harness Ground 94 to Throttle BR/W 0.5 6 FALSE TRUE Y 2/11/2023 In Digifant wiring harness Ground 94 to Hall Sender BR/W 0.5 6 FALSE FALSE Y 2/11/2023 In Digifant wiring harness Ground 94 to Water Temp. Sensor BR/W 0.5 6 FALSE TRUE Y 2/11/2023 In Digifant wiring harness Hall Sensor connector G/W 0.5 18 FALSE TRUE Y 29/10/2023 Hall Sensor connector R/BK 0.5 8 FALSE TRUE Y 29/10/2023 Hall Sensor connector BR/W 0.5 Ground 94 FALSE TRUE Y 29/10/2023 94 ground Engine water temp. sensor BR/G 0.5 10 FALSE TRUE Y 2/11/2023 Engine water temp. sensor BR/W 0.5 Ground 94 FALSE TRUE Y 2/11/2023 Z1. Injectors R/Y 1.5 FALSE FALSE Already fixed. But can be enhanced. Signal radiator Fan near ISV FALSE FALSE WIP ISV W 0.5 FALSE FALSE ISV BK/Y 0.5 FALSE FALSE Quote Share this post Link to post Share on other sites
KarlosG60 2 Posted November 26, 2023 UPDATE Hi everyone. After two weekend I return to real important things: my Corrado. Previous day got pending to install charged battery and check voltage at hall sender. So this is what I did today and voilà! I got 11.20V at Hall Sender connector! 💪 I checked spark, turning distributor by hand: all good. So I tried to run the engine and it run up easy but very bad idle. Need to adjust ignition timing and CO2. So, I think I can say this issue is (finally) closed. Quote Share this post Link to post Share on other sites
Popeye775 16 Posted November 27, 2023 Good job 👏🏻👏🏻👏🏻 hopefully this solves your issue. Keep us updated when you do timing and adjust the CO pot on how it is running 1 Quote Share this post Link to post Share on other sites
KarlosG60 2 Posted December 4, 2023 Hi, Just did the timing. I don't know if it's perfect, but the engine can run up, the "only" issue now It's I think injector #3 is dead or stuck, because spark plug #3 every time I run up engine and dismount them, it's completely dry and clean. So next I'm gonna need to do is dismount the injectors and send them to repair and clean. I will open new thread about this if I need some hints. Thanks you guys for your help in fixing my car wiring. Quote Share this post Link to post Share on other sites
Popeye775 16 Posted December 4, 2023 (edited) What spark plugs are you running? Are they OEM heat spec? To me, the plugs look a bit fouled - 1, 2, and 4 - as if they are carbon fouled or if your air:fuel mixture is too rich. Somebody please correct me if I am wrong on this though. Also, please remind me, do you have a Bentley manual or a version of it either PDF or printed? Edited December 4, 2023 by Popeye775 Quote Share this post Link to post Share on other sites
KarlosG60 2 Posted December 5, 2023 (edited) 10 hours ago, Popeye775 said: What spark plugs are you running? Are they OEM heat spec? To me, the plugs look a bit fouled - 1, 2, and 4 - as if they are carbon fouled or if your air:fuel mixture is too rich. Somebody please correct me if I am wrong on this though. Also, please remind me, do you have a Bentley manual or a version of it either PDF or printed? They are OEM, Beru. But +10 years old. They don't have too much mileage (I'm sure < 3000kms), but they are old and a lot of cold start-ups + fuel supply issues + ignition issues. The mixture I'm sure is not good, because before I found wiring issues, I manipulated CoPot and so... I will set to 500ohms. Yes, I have Bentley. But before replace spark plugs I think I'll check/listen with stethoscop/clean the injectors. Also I will check if exists spark on every spark plug. Edited December 5, 2023 by KarlosG60 Quote Share this post Link to post Share on other sites
Popeye775 16 Posted December 5, 2023 Be sure to follow the Bentley when setting the CoPot and things of that nature. Only reason I say this is because, I had played with my CoPot at one point (set it to 500ohm because it was in the thousands for whatever reason. I am almost positive one of the previous owners set it that high but I am unsure) and mine did not run very well. My AFR was way off. So just be sure to follow the Bentley when it comes to setting that mixture up. If you don't have one, I recommend getting an AFR gauge as this will make it easier to set the CoPot when adjusting everything. If you need help with it at all, feel free to PM me here or on the Vortex as well (same username on there). 1 Quote Share this post Link to post Share on other sites
KarlosG60 2 Posted December 8, 2023 Thank you @Popeye775 I will open a thread on Vortex, to talk about bad fuel mixing. I know this a so talked topic about, but not always they are good. Thanks for the advice for AFR gauge, I will definetely take a look. Quote Share this post Link to post Share on other sites
Popeye775 16 Posted December 8, 2023 Anytime. It can be tough to really dial in that CoPot without use of an AFR gauge. At least, from my experience it is because you don't know how your fuel mixture is while you are trying to set it. I have a wideband gauge mounted in mine that I used to fine tune mine. Quote Share this post Link to post Share on other sites
KarlosG60 2 Posted December 9, 2023 Before I open the thread there (no time now), this is what it need to be replaced on every injector? https://www.volkswagen-classic-parts.com/catalog/en_global/search?q=030 198 031 This item x4 times? 40 euros on that? There is another option? I saw Topran one, but this brand is not reliable I think... And we talking about fuel is an important system of the car. Cannot mount poor materials. Quote Share this post Link to post Share on other sites
Dox 23 Posted December 9, 2023 On 12/4/2023 at 11:01 AM, KarlosG60 said: Hi, Just did the timing. I don't know if it's perfect, but the engine can run up, the "only" issue now It's I think injector #3 is dead or stuck, because spark plug #3 every time I run up engine and dismount them, it's completely dry and clean. So next I'm gonna need to do is dismount the injectors and send them to repair and clean. I will open new thread about this if I need some hints. Thanks you guys for your help in fixing my car wiring. Plug 3 is clean, is the piston top clean too? Quote Share this post Link to post Share on other sites
KarlosG60 2 Posted December 9, 2023 1 hour ago, Dox said: Plug 3 is clean, is the piston top clean too? No. All four are dirty, but if i'm not wrong, piston head are black, so I can't assure you 100%. BUt looking at how spark plugs came out every time, it's very possible they are. I have pending to buy a mobile endoscope accesory to look inside the cylinder. Quote Share this post Link to post Share on other sites
Popeye775 16 Posted December 9, 2023 11 hours ago, KarlosG60 said: Before I open the thread there (no time now), this is what it need to be replaced on every injector? https://www.volkswagen-classic-parts.com/catalog/en_global/search?q=030 198 031 This item x4 times? 40 euros on that? There is another option? I saw Topran one, but this brand is not reliable I think... And we talking about fuel is an important system of the car. Cannot mount poor materials. When I did mine, I did not rebuild. I bought rebuilt injectors instead because I did not have means of testing the injectors once they were rebuilt. It was easier for me to buy certified/tested rebuilt injectors than it was to get a rebuild kit and take to a shop to have flow tested. Your injectors may be ok, but could be that the CoPot is tuned too rich. It is never a bad idea to freshen up the injectors, but I would test fuel pressure/fuel pressure drop to see if the injectors are leaking or needing to be replaced. Make sure the fuel pressure is good and then shut the car off and keep the pressure tester connected. Bentley should outline how long to keep it connected for and how much of a fuel pressure drop there should be. This will help to show you if your injectors are leaking Quote Share this post Link to post Share on other sites
KarlosG60 2 Posted April 7 (edited) Hi, Today I cleaned injectors one by one using syringue as a fuel ramp, and a lot of PTFE to keep the pressure inside. I saw how the spray on every injector became from 3-4 streams to a visible an audible spray. So, for me are cleaned and ok, but didn't check for leakings. Maybe in the future. First I want to know if the car will run well. My doubt now it's about the seals replacements. My injectors reference are: 0280150905 and this is the reference ETKA says: 030 198 031 VWClassic has stock, but I don't know where the gray seal and one of black seals are fitted: My injector: Two of black seals, one orange at the end. But the other two? I don't have here the injector, buy maybe the gray it's near the orange? Edited April 7 by KarlosG60 Quote Share this post Link to post Share on other sites
KarlosG60 2 Posted April 7 (edited) I just bought a pack of 4 seals set por 8EUR from BOSCH. Comparing references it seems the same. But didn't come with the micro-filter like this set does: https://www.ebay.es/itm/332423959672 What size this filters has? In AE there's a lot of them Edited April 7 by KarlosG60 Quote Share this post Link to post Share on other sites
Popeye775 16 Posted April 9 In my experience, buying rebuilt ones has always worked out better for me. Saw it easier to buy rebuilt injectors that came with a warranty in case they didn't work than to try to rebuild mine and have the chance of them not working ahaha. Maybe somebody else can point you in the right direction of rebuilding them. Do you have Bentley? Does it explain what all needs to happen in order to rebuild? Also check 7-zap if you haven't already to find OE part numbers if you need for any of the rebuild of the injectors Quote Share this post Link to post Share on other sites
KarlosG60 2 Posted April 13 (edited) Hello I have the O-rings sets. But I don't understanding what is talking about here. What I should replace? Which part is yellow here? I only see ORANGE. Am I daltonic? Edited April 13 by KarlosG60 Quote Share this post Link to post Share on other sites
KarlosG60 2 Posted June 28 (edited) Update (yes, i'm slow. I do it when I can. Don't have own garage/good place to work on it) Next step. Mount them and we will see what happens. Edited June 28 by KarlosG60 Quote Share this post Link to post Share on other sites
