Dox
ABV block, wiseco pistons job lot
JOB LOT!
New boxed Wiseco 83mm pistons
ABV Tall block (bottom end and head complete) turns over with a ratchet on the crank bolt, bought off a forum member here, stored by me for 7 years.
VR6 gearbox from a car I bought with wrecked engine (should be good)
Mk3 16v gearbox - bought as good for its diff (3.65) to go in my VR6 box
Hot Golf (Gas n Gears) lightened flywheel 6KG from memory (10KG standard)
02J shift tower - from one of my own cars (known good on removal).
Polo shifter, bought as good, should bolt straight to the transmission tunnel in a corrado.
All the above was amassed to build an engine / box for my car, it’s never going to happen TBH
Collection from Crewe Cheshire 10 mins J16 M6
£1200 (new price of the pistons)
Ideal to build an engine / box whilst you still use your car, refit your original if you decide to sell the car on.
9 minutes ago, russ964 said:
Wana sell the flywheel separately?
No, around £90 from Gas n Gears of fb
