Jim H 10 Posted July 19, 2023 Hi all, With knowledge that the headlights slightly changed during production. The early cars part number is 133 163 00. The part number on my vehicle is 141 093 00. Mine is a later car, 94 registered. Are these parts interchangeable? Early part to fit later headlights - they look identical? This is the black plastic outer surround which clips on from the front of the headlight. Regards Jim. Quote Share this post Link to post Share on other sites
Dox 31 Posted July 19, 2023 As far as I’m aware, the light housings are the same, the lenses and surrounds changed for the late models Quote Share this post Link to post Share on other sites
Jim H 10 Posted July 20, 2023 Hi, it’s not the actual headlight body I refer to, it’s the black plastic trim that surrounds the front of the lense.. im not actually a newbie, I just couldn’t figure out how to post this in the exterior section. Regards Jim. Quote Share this post Link to post Share on other sites
Dox 31 Posted July 20, 2023 6 minutes ago, Jim H said: Hi, it’s not the actual headlight body I refer to, it’s the black plastic trim that surrounds the front of the lense.. im not actually a newbie, I just couldn’t figure out how to post this in the exterior section. Regards Jim. You need to be a paid member to post in most areas of the forum. Quote Share this post Link to post Share on other sites
Dr_G60 0 Posted July 28, 2023 that black plastic frame is not interchangeable. Cheers Gunther Quote Share this post Link to post Share on other sites
