davidwort 0 Posted August 17, 2004 Anyone know if the plastic guide that is attached half way down the gear lever shaft and connects at 90 degrees to the selector housing part of the mechanism wears at all? It's the sleeve of the bit that the gear lever effectively pivots forwards an backwards on, and is held in place with a circlip (see pic) It seems to be the part that's allowing quite a bit of left-right wobble/play in my gear change, and it's only a couple of quid. cheers, David. Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted August 17, 2004 If it's that cheap, buy it and try it. Are you sure it's not 24 or 48 that's worn? Or is it 11 thats moving around a lot? If it's been used for a while (it has) particularly with worn engine/gearbox mounts it will probably all be a little worn... Quote Share this post Link to post Share on other sites
