jedi-knight83
tinting OE rear lights...just the orange bits to match
The best tape to use is Tamiya model tape, available from most hobby shops. It's a lot thinner and more flexible that regular masking tape. And it sticks better too!
Hi guys,
Seems most points have been covered. I've copied and pasted the method I used from a previous post on this subject. I used 3M fineline masking tape and removed it while the paint was still soft to avoid cracking the paint when it hardens.
Cheers
Asim
*Choose a warm sunny wind free day!
*I rubbed down all the raised lettering first with 600 grade wet and dry.
*Do the whole lens surface with the same grade to get a key.
*Wipe surfaces with alcohol based degreasant.
*Mask the stipes on the indicator lens. If you look closely on the lights they are made up of a plain plastic row and then a "crystal" effect row. I masked the crystal row (so this will stay amber).
*Mask up the brake light and the black plastic suround and black middle stripe.
*Spray the red lacquer (I used FoliaTec) evenly in thin layers. I between layers put the light in the sun to cure.
*Keep building up the layers until you're happy it matches the brake light lens.
*Remove the masking tape after an hour.
*Allow to cure for the rest of the day and overnight.
*Give the red lacquered surface a very fine key with 1000 wet and dry.
*Wipe down all the lens surfaces, including brake light. Mask up the all the black plastic parts of the light.
*Spray all the lens surfaces with clear lacquer.
*After about a week rub down the lacquer with a mild car polish like AutuoGlym SuperResin to get a high gloss finish.
