rmn 0 Posted August 19, 2004 Right i am going nuts, it seems to be the time of the year for people to do suspension overhauls on their cars, so i got in on the act I got my coilovers and said i would start at the left front and work my way round, and while i was at it i would do the suspension bushes well the coilover and new top mount flew into place, no problem, then i moved onto taking the wishbone out, or not i have tried using a power bar, an air impact driver(not the most powerful one mind you) and everything else i could find to try and open either the front bush bolt or the rear bush bolt Has anyone got any suggestions on a way of getting this out, i am going slowly mad, i dont want to round the bolts and totally knacker myself thanks Quote Share this post Link to post Share on other sites
dtjames 0 Posted August 19, 2004 WARNING: Wishbone bolts have a nasty habit of shearing. Expensive cutting/welding job to rectify. Good Luck. Quote Share this post Link to post Share on other sites
Rpmayne 0 Posted August 19, 2004 Have you tried heating them up with a blow torch or something? I did this on a mk2 golf and they came off no probs, it was getting the bushes out which was the nightmare. Quote Share this post Link to post Share on other sites
dinkus 10 Posted August 19, 2004 Err before you try any of that, drench the bolt in PlusGas. It's kinda like WD40 but on steroids. Leave it over night and it will penetrate (ooh err) the bolt and it should come off much easier in the morning. Quote Share this post Link to post Share on other sites
rmn 0 Posted August 20, 2004 tried soaking it in oil, i rekon a blow torch will work on the rear buh, but nor sure about the front one Quote Share this post Link to post Share on other sites
h100vw 0 Posted August 20, 2004 The one that goes up in the box section under the footwell is the b1tch. I doubt plus gas would climb the length of that bolt. A geezer at a dealer told me to try doing it up a bit first. This worked a treat on my MK2 at the time. Use your bar. Gavin Quote Share this post Link to post Share on other sites
rmn 0 Posted August 20, 2004 thanks, i didnt try the tighten up bit, but it does make sense Quote Share this post Link to post Share on other sites
Geo 0 Posted August 20, 2004 Richard, did you try beating the shit out of it with a hammer? Works for me most of the time (and makes you feel a lot better too) Quote Share this post Link to post Share on other sites
King_prawn 0 Posted August 20, 2004 I used a 3 foot pipe on a t-bar to crack the front bolts. Had a nightmare splitting the lower ball joint though. Other than that everything went smoothly. Make sure you've got the right rear bush if using powerflex. Burn the old ones out and cut the metal sleeve in 2 places, it comes out easy then. Quote Share this post Link to post Share on other sites
rmn 0 Posted August 20, 2004 ok, i got the B@stard bolts out! the front one is not a 17.5mm :evil: I have a quick question, should i go out to gsf and get some wishbones tomorrow or remove the old bushes and reuse the wishbones i took out? I spent a few minutes with an air hacksaw trying to remove the bushes and said i would leave it til tomorrow are the gsf wishbones ok to use or are they crap? thanks Quote Share this post Link to post Share on other sites
exturbo2003 0 Posted August 21, 2004 i think you will find that gsf do the wishbones without the bushes in them so are a lot easier to do Quote Share this post Link to post Share on other sites
rmn 0 Posted August 23, 2004 yeah i ordered ones off gsf without bushes thanks Quote Share this post Link to post Share on other sites
