boab 0 Posted August 20, 2004 ive just had all my pipes replaced and everything was fine, so with it all running wel with no leaks i drove to the garage to put some petrol into my car, started fine no problems!! but once i had filled up i went to start the car and nothing happened! i tried and tried and nothing happened wasnt even ticking over, so i pushed it to the side and my grandfather came with some jump leads and i still wasnt getting it to start, so i had to get towed back and on way back i bumped it easy enough, so car was running again, stopped and drove home but when i stopped and turned engine off it was dead again, has anyone any ideas what could have caused this or what it sounds like? starter motor maybe?? or what checks i can follow out Quote Share this post Link to post Share on other sites
bighairymuppet 0 Posted August 20, 2004 check this dude may help i p[osted in it previously it gives you a way of checking the starter motor by hotwiring incase its n alarm or the ign switch :-) good luck man. http://the-corrado.net/.archive/forum/viewtopic.php?t=13354&start=0&postdays=0&postorder=asc&highlight= Quote Share this post Link to post Share on other sites
dr_mat 0 Posted August 20, 2004 Check the copper current strap from the battery to the solenoid, THEN check the copper current strap from the solenoid to the starter. This gave way on mine, so I was just getting TICK, TICK on trying to engage the starter, but no actual rotation.. Quote Share this post Link to post Share on other sites
Henny 0 Posted August 20, 2004 bump starts but won't start off the key? I'd say ignition switch was probably at fault... There's a LOT of threads about it on here, do a search and you'll find lots of tests and things to see if it is or not... There's a guide to fitting a new switch in the how to section... Good news is that if it's the switch it should only take you 30 to 45 minutes and only costs about £25... 8) Quote Share this post Link to post Share on other sites
