MarkGolf
Exhaust removal (VR)
Trying to remove the exhaust system from my corrado..
Still has manifold attached as all the bolts are rusted and just fall to bits as soon as a spanner touched them..
Just need advice
The exhaust goes over the rear axle, do you HAVE to cut the pipe or is there a technique?
Thanks
You either cut the pipe or you drop the rear axle... And those rear axle bush bolts can be complete nightmares if they've never been removed.
Good time to get the rear axle bushes changed anyway, if they haven't already been done! :)
Will have to cut it!
Had to remove the rear axle on my golf and replace it which wasn't fun!!
Can't stand rusty bolts!!
Thanks!
