destructiv dave
Mental clocks + dials
Mates just bought a 94 L reg 2l 16v which is all working except for the dials, which when cold flicker on (revs up to standard 900ish etc.) before flicking off then back on, then off and on etc. every 0.50 sec.
The time doesnt reset back to 0:00 on the MFA and not sure about the other functions as I am not quick enough to scroll through the functions.
I have tested the wiring by using another set of clocks and they work fine so I am left with the knowledge that it is the clocks themselves.
I have split the front from the back but am now stuck as to what I should do next.
i have checked the search function and it is not an issue that seems to have been raised before, so hoping some electrical guru can give me some pointers.
Cheers,
Dave
Have experienced a simillar problem to this and it transpired to be a deffective printed circuit, which once replaced cured the fault.
Thanks for the swift responses. Will take a look at the printed circuit board, if nothing stands out then I guess I will have to change parts between the 2 sets of clocks I have at my disposal to make 1 fully functioning nice looking set.
Once again, thanks
Dave
