jamy99
sunroof and interior light trouble
My sunroof and interior light on my 1.8 16v recently stopped working. I then found out by accident that if I opened either door they worked fine. Has anyone else had this problem and been able to fix it, otherwise does anyone have any advice?
Cheers
thats got to be a switched live problem somewhere i would think. but i havn't got a sunroof so i dont know for sure
Prise off the little unit that contains the lights and sunroof switch.
There's a circuit board on it that may have a dry joint.
If you're handy with a soldering iron you can fix it yourself.
I know Mk3 Golf and early nineties Passats have interchangeable units with the later Corrado's.
Not sure about the early interior ones though.
Try someone breaking an early C on the Forum.
Have replaced the circuit board now but still have the same problem, have checked it for dry joints and they all seem fine, anyone got any ideas?
thanks a lot
