mariovr6
vag com where to buy?
hello
just wondering where i can get a corrado fault finder?
been halfords and the sell VW ones but it only says on the box ( golf passat vento vr6 ect is this the correct one? where do a get a corrado vr6 fault finder from? also is the more expencive £99 one any use?
It should work on the Corrado, but bear in mind the cheapo ones will only report error codes, they won't tell you what those codes MEAN.
Real VAG-COM is the dogs doodads and it'll cost you $229 (US) with a permanent license and a suitable cable. You need a laptop but it's the best one out there, short of the VAG-only 1551 and newer tools, which will set you back a LOT more than that. You can use third party cables with VAG-COM too, but any cable at all is going to cost around £40-50 it seems.
