Rossco 0 Posted September 22, 2004 Could you look up this part number and give m ethe description, ive got etka but it wont let me input part no's Part no: 357 906 363 Cheers guys Ross Quote Share this post Link to post Share on other sites
VR6 0 Posted September 22, 2004 Retardation relay for fuel pump Quote Share this post Link to post Share on other sites
Rossco 0 Posted September 23, 2004 thank you very much mate, next question What the hell does that do???? :lol: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 23, 2004 Something to do with the rev limiter?? Quote Share this post Link to post Share on other sites
Banana Man 0 Posted September 23, 2004 In etka it lists it as a a fuek pump retardation relay whatever that means???? But looking at the diagram and location it doesn't make sense as it says it locates in relay position 13, which is the abs pump relay according to the bentley manual. I personally think it is probably the fuel pump after run relay. Where on your relay panel is it located is it above the main 2 rows of relays up on the top of the fuse box??? If it is then I would put my money on it being the after run relay! Hope this helps! Quote Share this post Link to post Share on other sites
Rossco 0 Posted September 23, 2004 Yep its above the 2 main rows, it actually clips onto the top of the fusebox so i just clipped it off and its still attached to the loom at the moment Quote Share this post Link to post Share on other sites
G60Jet 1 Posted September 23, 2004 Something to do with the rev limiter?? i always thought the rev limiter just cut the spark? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 25, 2004 Supercharged wrote: Something to do with the rev limiter?? i always thought the rev limiter just cut the spark? Yeah, that makes more sense.. last thoing you want to do is run a FI engine lean! :? Quote Share this post Link to post Share on other sites
Banana Man 0 Posted September 25, 2004 Something to do with the rev limiter?? i always thought the rev limiter just cut the spark? You would be right nigel :D It's more likely to be the fuel pump after run relay!!! IMHO Quote Share this post Link to post Share on other sites
Scruffythefirst 0 Posted September 26, 2004 Something to do with the rev limiter?? i always thought the rev limiter just cut the spark? Some rev limiters just cut the spark, typicaly every other firing for a soft cut and every spark for a hard cut. Some also cut the fuel by not turning the injectors on so you dont get unburnt fuel in the exhaust which wouldn't do the cat any good. Quote Share this post Link to post Share on other sites
