bazgreener
faulty lambda probe on g60
Hi Folks,
I think the heater on my lambda probe is packing up, i have an air fuel gauge and the fuelling is only cycling when i drive the car hard or on the motorway, also mpg is down. Can anyone recommend where i can get a new one as GSF don`t do one and it seems it may be a main dealer only part $$$$$ :p $$$$$ anyone ever used one of the universal probes?
cheers
Barrie
i got a univeral one from gs&f and it seems ok, turned out that wasnt the problem after all but then with a c nothing is ever that easy. think it was about 30 quid
funk
I was same bought GSF £30(if u want it i would sell u it for £15 posted,is fairly new used for month or two)mine was same didnt need it(blue temp sender)also just posted above to someone,check the actual wiring to your probe for snapped melted wires(maybe a cheap fix)
Do you know what voltage the universal sensors work on? I think the g60 and most vw`s are 1.2v max and most other manufacturers use 1.5v
Baz
