stormseeker 0 Posted May 22, 2003 since it's been raining for the last week solid, I thought I'd take a look at how my tailgate leak was doing - very nicely thanks - spare wheel well sloppy & horrible. :( :shock: But, seeing as there has been such a torrent into the car it's easier to see where it's coming from. It's coming through the tailgate somewhere, possibly wiper arm or spoiler actuators as it's dripping off the back trim panel in the tailgate when it's raised. got to climb in the back with the seats down, trim panel off & wait for the next big downpour - shouldn't be long... Quote Share this post Link to post Share on other sites
2cc 0 Posted May 22, 2003 Chris, I had the little plastic plugs that hold the Corrado name badge on the rear panel split - couldn't believe how much water got in through there. Bloody gallons, I had the carpets out for months before I figured out where it was coming from. Not the same problem you have got, but it might be worth having a look at the mounting points for the number plate panel as that has small attachment pegs that penetrate into the tailgate. They also have a habit of breaking off as they are pretty fragile. Mind you, I know a couple of mine are busted, but x-fingers no water gettting in there - yet! Good hunting Quote Share this post Link to post Share on other sites
stormseeker 0 Posted May 22, 2003 Chris, I had the little plastic plugs that hold the Corrado name badge on the rear panel split - couldn't believe how much water got in through there. Bloody gallons, I had the carpets out for months before I figured out where it was coming from. Not the same problem you have got, but it might be worth having a look at the mounting points for the number plate panel as that has small attachment pegs that penetrate into the tailgate. They also have a habit of breaking off as they are pretty fragile. Mind you, I know a couple of mine are busted, but x-fingers no water gettting in there - yet! Good hunting Thanks, I'll check the Corrado badge pins & all the others + the number plate surround too as I know the previous owner had to replace all the rear badges after they were knicked. Just noticed a couple of drain holes in the underside of the tailgate that are supposed to drain outside of the seal - wonder why it's not draining there??? Quote Share this post Link to post Share on other sites
the delta force 0 Posted January 21, 2008 Now I know where my leak is coming from.... It must be the badge Quote Share this post Link to post Share on other sites
Reggit 0 Posted January 27, 2008 Had mine leak on the badges and the tailgate hinges, there's a gasket where the tailgate bolts to the roof, that had failed on mine and bucket loads of water used to get in. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 27, 2008 Now I know where my leak is coming from.... It must be the badge Only 5 years after the last reply!! Quote Share this post Link to post Share on other sites
