aposegil 0 Posted October 9, 2004 Hello guys went to try and take the car to MOT today but knew the brakes need proper bleeding. For bleeding I have a bottle that attaches to the resovoir and you pump it up to 1 bar 14.7psi so that it pushes the fluid thorough the system nicely :) anyway went to bleed the rear first and nothing!!!! nothing was coming through at all, i have changed the lines to braided but otherwise done nothing else except the car sitting there fronts the fluid went throught 100% including clutch system so what could have happened for nothing to come out of the rear??? thank you in advance Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted October 9, 2004 can only think of the compensator jamed shut :? Quote Share this post Link to post Share on other sites
W3RKD 0 Posted October 9, 2004 did you have the compensenter clamped open when trying to bleed the rears ? Quote Share this post Link to post Share on other sites
aposegil 0 Posted October 9, 2004 whats the compensator ??? is this the valve controled by the rear axle beam??? if so i jacked the beam from fully down to fully up and made no difference :( and i did have the nipples off coompletely even tried pumping the brake pedal Quote Share this post Link to post Share on other sites
aposegil 0 Posted October 11, 2004 isnt there no one that can point me in the right direction??? even how to test which bit could be fualty ?? Quote Share this post Link to post Share on other sites
