Beetleman65 0 Posted October 17, 2004 Hi guys After exhaustive searching through about a million web pages I need an idiot's guide on how to replace the auxiliary water pump, which I think is leaking like a leaky thing :( . What was a sporadic problem now seems to be more regular, spits out about one litre of coolant but doesn't do this regularly :( . I have sent her down to my local friendly VW specialist, when she won't perform :? . Rather than spend even more time without her I would like to replace the auxiliary water pump, I don't think it's the expansion tank filler cap but I'm doing that tomorrow .Almost forgot she is an M reg VR6 (1994) with 95000 on the clock) :roll: . Any help would be much appreciated from you guys who seem to know all that there is to know :wink: . Many thanks Graeme Quote Share this post Link to post Share on other sites
Ice White Socks 0 Posted October 17, 2004 Don't forget the expansion tank itself- they can leak too. I've just had both the tank and the aux pump replaced to cure just the same thing :( Quote Share this post Link to post Share on other sites
Beetleman65 0 Posted October 21, 2004 Thanks Ice White I'll check it out in between showers this weekend :) Quote Share this post Link to post Share on other sites
dav 0 Posted October 22, 2004 you might have to modifiy the plug on the Aux Water pump as i had to, nothing major just a different type of plug. but as yours is an M plate you should be cool. Quote Share this post Link to post Share on other sites
