Mk1GLS
Plumbing help.......
Hi all,
dont think I have posted this up here b4 if I have apologies. it has been in my mind for a while.
I am trying to put the finishing touches to my VR6 Mk1 Scirocco & have come to the heater. On Corrado's etc the heater works different to a rocco The water always travels round the circuit & the heater control changes the air direction rather than the water flow, rather than on a rocco there is a valve controlled by the heater slider that reduces / cuts off the water flow (the plumbing is made for this) So on the VR6 I can't slow the water flow down to the scirocco matrix in the normal fashion as since the engine is designed to have this flow I assume it would be not good!
So I was thinking (carefull!) I wonder if there is some car out there that has a T or Y valve fo the water. So as you move the valve it changes the wayer flow. that way I can (with the use of one way valves from a 16v) use this to bypass the matrix.
Anyone know of how this has ben done before with Vr6's into Mk1 Golfs etc? Or have any ideas.
All thoughts appreciated.
cheers
