RaddoPL
Clutch not disengaging in 1990 VW Corrado
When I push down my clutch, it goes down with no resistance, and stays down. There is a small puddle of fluid under my car. The brake fluid reservoir is full. Seeing as how this is a hydraulic clutch, there is obviously no pressure acting on the pedal by the cylinder to push it back. Where could it be losing the fluid from? :?:
Slave cylinder next to g-box. If you've got fluid leaking it shouldnt be too hard to find the source - wipe all joints clean then press the pedal. the cullprit should then become obvious.
