Oakley 0 Posted October 26, 2004 Hi All Seems my C's Lamda probe was the cause of my fuel consumption problems. Replacing it has also solved my rev dipping and cutting out problem so thanks to all for your help. Oakley Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted October 26, 2004 did you clean the isv or did the lambda sensor work so you didnt bother ? Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted October 27, 2004 was it throwing a vagcom error? consumption is awful on my VR and this may be a cause. alternatively my heavy right foot may also be to blame ;) Quote Share this post Link to post Share on other sites
tonytiger 0 Posted October 27, 2004 pablo_vr6, how awful? And what sort of journeys do you typically do? Quote Share this post Link to post Share on other sites
Oakley 0 Posted October 27, 2004 I forgot all about the ISV as it seems that the lamda resolved my problems but for how long I wonder. I will still clean the ISV when I get the chance just in case. I have been told that the Lamda error code will be stored in the ECU and it needs a reset! I am also told just disconnecting the battery for 25-30 minutes will clear this code. My question is, which battery leads do I dis-connect, or is it just both of them? Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted October 27, 2004 pablo_vr6, how awful? And what sort of journeys do you typically do? over the last 1000 miiles Ive been getting 22mpg - mixture of motorway and town driving but mostly Aroad/motorway Oakley - not sure if unplugging will reset the codes mate might need vagcom to do it. If you do disconnect the batt just pop the negative off - no need to do both Quote Share this post Link to post Share on other sites
Oakley 0 Posted October 27, 2004 Pablo, The Vag was saying that my Lamda was intermittent, hence the replacement thanks to Reggit whi diagnosed the problem. Get yours on the Vag if it is heavy. Mine was throwing out 17mpg on the motorway @70mph which was extreme as far as I am concerned. Oakley Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted October 27, 2004 damn that is extreme - been on vagcom and no codes so looks like I just need to lay off the loud pedal :) Quote Share this post Link to post Share on other sites
Oakley 0 Posted October 27, 2004 LOL, I think you are probably right with that one Pablo, but you know if you drive a VR, it is impossible to lay off the gas when some dumba** clio tries to make you look stupid, no VR driver would stand for that! Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted October 27, 2004 I blame carbonio for making such sweet music under my bonnet :D Quote Share this post Link to post Share on other sites
Oakley 0 Posted October 27, 2004 To me there is nothing nice sounding that 2nd gear kicking in at 4000-6000. Quote Share this post Link to post Share on other sites
tonytiger 0 Posted October 28, 2004 over the last 1000 miiles Ive been getting 22mpg - mixture of motorway and town driving but mostly Aroad/motorway That does seem a bit excessive. My normal commute is an 80 mile round trip, mixutre of slow moving / town driving also with motorway and unclassified country road. I'm not exactly light on the throttle myself (it's just not possible in a vr :D ) but I still average 28mpg or more usually (measured properly - not just the MFA reading). Unless you have a fairly short journey compared to mine, I would be a bit worried about that economy. When mine dipped to 22mpg average and below back in August vagcom reported lambda errors on mine (which doesn't necessarily mean it's the lambda though). Could be worth plugging vagcom in on a fairly regular basis for a while (if you've got your own) just to see if any errors are thrown up. Oakley, good to hear yours is okay now. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted October 28, 2004 I do 15 miles/day round trip and average 22-24 mpg. That includes motorway sprint each way. It's just not long enough to get these big engines into their efficient band... Quote Share this post Link to post Share on other sites
Oakley 0 Posted October 29, 2004 I think you are right Mat, I would imagine it needs a bit of a longer run. By the way, does anybody else see this, My rado when i am at a light or something and I am watching the Mpg, it seems to tick down slowly, very slowly, is that normal at a standstill? Quote Share this post Link to post Share on other sites
Reggit 0 Posted October 29, 2004 Completely normal, it is an average reading of fuel used v's distance travelled. When you're at a standstill with the engine running you're using fuel and going nowhere, hence the average MPG is decreasing slightly. Quote Share this post Link to post Share on other sites
Oakley 0 Posted October 29, 2004 Thanks Reggit, 1 thing less to worry about now. Quote Share this post Link to post Share on other sites
