Neil L. 0 Posted November 7, 2004 Hi ,new to this forum & would appreciate some advice. Been to view a very nice Corrado with a view to purchase. The car is in cracking condition(inside & out) but for some reason the battery tray is corroded quite badley just behind the passengers side headlight. There's no evidence of rot anywhere else on first viewing and possibly could have been caused by a leaky battery?(The battery looks quite new - not original fitted).How serious would you consider this to be in respect to buying the car(cheap to fix?) as the owner wants a quite healthy price for it (plenty of money spent & a very good history on the car). What do U think?.......... Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted November 7, 2004 Battery moving around and damaging the paint, battery leaking a little plus all the salt etc that gets into this area around the headlight is the cause. The replacement panel is less than £40 from VW (last checked 2 years ago mind), but fiting it is likely to be expensive as the front of the car will have to come apart. Having the existing tray cut back to sound metal and a patch welded in (then properly painted/seam-sealed etc should last a long time. Quote Share this post Link to post Share on other sites
Neil L. 0 Posted November 7, 2004 Thanks Mike, would probably opt for new VW tray as car is in great condition(if i purchase!) - anyway of me checking online the current price or the part? Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted November 7, 2004 Ask for 535 803 093 " Bracket - battery" at a VW dealership. Quote Share this post Link to post Share on other sites
warcraft 0 Posted November 9, 2004 £36-54 inc vat from the main stealers and about 2 hours odd to fit Quote Share this post Link to post Share on other sites
craigowl 0 Posted November 9, 2004 Prevention is better than cure. You can keep your battery trays for ever if you cover them with (thick, hard) waxoyl or similar. Quote Share this post Link to post Share on other sites
Neil L. 0 Posted November 10, 2004 Thanks Craigowl but im not the actual owner - Im planning to buy the said Corrado! Probably would have looked after it better if it were mine! Anyway thanks for the advice....... Quote Share this post Link to post Share on other sites
