jedi-knight83 0 Posted November 9, 2004 Well i bought a spare ABS ECU from ebay.. got it for £30. Old one is easy to get out...just one bit of trim and a few bolts. Anyway the old one had horrid green corrosion in the connectors.... so i cleaned up the plug and fitted the new one and put vaseline around the edge of the plug to hopefully stop it happening again.... ...anyway been a couple of days now and no ABS light yet...fingers crossed 8) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 9, 2004 Corrosion on the plug in the *interior* of the car? Has your car been leaking water in at all? Could explain it.... Sounds like it's fixed anyway, and for £30.... can't grumble at that 8) Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 9, 2004 Wait and see..... Mine has weeks where it'll behave perfectly then the light will be on all the time.... PLUS you bid on the one I won the other week too, ya git. You cost me an extra six quid.. ;) I reckon that's two pints in ye olde Cambridge pubs. Mine's a Guinness!! :lol: Quote Share this post Link to post Share on other sites
jedi-knight83 0 Posted November 9, 2004 Corrosion on the plug in the *interior* of the car? Has your car been leaking water in at all? Could explain it.... Sounds like it's fixed anyway, and for £30.... can't grumble at that Yeah i had the dreaded damp passenger footwell for a while bit i think its fixed now.. not been wet for ages?? :| dr_mat, sorry about the £6 i dont buy beers though...special religion i have :wink: and my light was coming on more regular the past weeks and now its not on at all :) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 9, 2004 Yeah the green powdery substance is what's created as the water dries off the connectors.....so although it was wet sometime ago, the damage had already been done. You may have been OK just scraping that away but if you got a short, then it could have burnt out something inside the ECU. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 9, 2004 dr_mat, sorry about the £6 i dont buy beers though...special religion i have :wink: and my light was coming on more regular the past weeks and now its not on at all :) Ah, I know people like you... First out the taxi, last at the bar... :roll: Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 12, 2004 Oh and to follow on from this story, the ABS controller I purchased for £16 was fitted today (by me!), and lo and behold I found some green powdery substance bridging a couple of contacts in the corner of the big fat multiplug on the old one. Cleaned up the connector, reinstalled the h/w and lo and behold, no more ABS light. Will have to check in the longer term but hopeful for the time being... :) Quote Share this post Link to post Share on other sites
Jim 2 Posted November 12, 2004 I can't help but notice a pattern emerging here... ;) Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 12, 2004 I can't help but notice a pattern emerging here... What, of Jedi not buying drinks? Yes, I know, terrible isn't it! ;) Quote Share this post Link to post Share on other sites
jedi-knight83 0 Posted November 12, 2004 i buy plenty of drinks thanks very much.........i just end up drinking them myself :roll: Quote Share this post Link to post Share on other sites
daveh 0 Posted November 14, 2004 Hi guys, Would like to check my ABS controller. Where abouts is it?? Dave. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 14, 2004 Passenger side, remove the 6 screws holding the lower shelf in place, remove it, remove the two screws visible in the plastic panel directly in front of the door, and the single broad fixing to the front of this panel, and lo and behold. One ABS controller. But bear in mind if it's broken there's pretty much nothing you can do but replace it. If you're lucky and there's a corrosion problem on the contacts, then you'll have to find out where the water's come from! Quote Share this post Link to post Share on other sites
daveh 0 Posted November 15, 2004 Thanks for the info.... Yet another thing to look at on my car. Why oh why does it run perfectly for months (or even years), and then eveything turns to s**t at the same time. Anyway, rant over.... New magnex exhaust arives this week. Can't wait!! Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 15, 2004 You're lucky. It's much more soul destroying when it runs shite all the time, and for every thing you tick off the list of fixes, you've added another three things in the meantime... Quote Share this post Link to post Share on other sites
daveh 0 Posted November 16, 2004 Just removed my ABS controller - contacts very 'blue' and corroded. Hopefully removing the corrosion will sort the problem. Now I just need to play that great game we all know as 'chase the leak'! P.S. If the ABS controller is knackered, how much for a replacement?? Quote Share this post Link to post Share on other sites
jedi-knight83 0 Posted November 16, 2004 daveh, get some contact cleaner from maplin or a similar store, spray on the ecu and the plug and then put the plug into the ecu a few times to clean it all up. ECU from VW would be £200 upwards i guess??? from ebay... £30 - 40 Quote Share this post Link to post Share on other sites
