theRuler
VR6 Gearbox oil change
I think i ought to do this.
I have not changed it before! my questions are -
which grade oil?
how much will i need?
is there some sort of funky tool required to remove the plugs?
is overfilling (by a controlled amount) a good thing?
1 - Redline MT-90 (75/90W)
2 - 2 bottles
3 - 17mm allen key
4 - impossible to overfill as it pours out of the filler hole when full.
thanks chief
overfilling can be done through the speedo cable hole (on older golfs anyway)
i heard it recommended once.
doh 17mm allen key though.
Try removing the speed sensor on the VR box though, not fun :lol:
You can overfill but I wouldn't as it will over pressurise the seals.
Halfords sell the 17mm allen key mate :lol:
......and another thing !
A very good tip, (found somewhere in here - acknowledgements to the originator), is to make sure you can undo the filler plug before you drain all the oil out.
Best wishes
RB
good looking out there rog!
