david ryley
water leaking VR6
I have a problem with water leaking into the passenger foot well, i've checked all the obvious like the matrix, and door seals! i don,t know if it could be coming in around the polum filter? has anyone had the same probs its doing my head in now........ :cry:
Firstly, to eliminate possibility of coolant from matrix, dab finger in it, taste it carefully, spit out well.
What is a "polum filter"?
2 possibilities:
The seal around the fresh-air inlet has perished and is leaking;
The waterproof memrane in the door is torn or missing.
I'm guessing he means the "pollen filter" fitted to some Corrados as an optional extra.
