20v turbo
4x4 conversion
right guys for those of you out there who have do it is there anything i should whatch out for,any tips or info would be appreciared 8),plan to do over crimbo hols :wink: if i get a chance.
hummm, I'll list off a few problem area....
Need to make a bracket from transfer box to engine block,
need to weld prop shaft brackets in the right place - important,
brake bias valve prob needed as 4wd one is crap,
need mk1 golf Gti suspension at the rear as corrado one is too long,
if your replacing the bearings on the rear then watch out as there are a few different srts, and therefore different sizes,
CV's are golf gti 100mm ones,
make sure you have all the standard mounts before you start, they take months to order from Germany if you need them!,
All in all it all fits up ok, if I can remember anymore I'll let you know, good luck! Ben
