duffer
Misfire in 1st
When driving my 16v, occasionally, but getting more regularly, when in 1st gear only, it will feel like its misfiring. When i change into 2nd it goes away!
Has anyone else had this problem, what would be causing it?
its probably just misfiring at low revs - sub 2000
you only really see sub 2000 in first.
check the usual stuff - airflow sensor connections, lambda probe etc . . . .
its a tough one to judge!!
i had problems like this recently which gradually got worse to the point where on 2 occasions it just stopped.
I needed a new distributor
I cried :cry:
