g-dub
G60 Samco hoses
fitting my new hose kit and there are 2 pipes left one that looks like a K and another that is a small 10cm straight pipe bout 30mm bore, where do they go please, i will try to post some pics
much abliged
The first one is it more of an 'h'? - if so it sounds like the water pump to heat exchanger pipes - you'll have fun with the small one, I think it goes between the pump and the metal water pipe...
Still picturing you head to toe covered in grime battling those hoses on!!
