fast x 0 Posted December 16, 2004 Hi guys i recently found that my auxi pump was leaking so my water temp was just a bit hot than normal so i got it changed and still the tem still higer than usual what else should i check???? maybe a new thermostat??? any help will be most apresiated. philip. also it is ok to drive the car on this type of water temp?? it sits just below 110????? but my fan it is working fine and when im on the motorway it goes down as normal. also i would like to kwon what is the stat????? and where i can find it. thanks again. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 16, 2004 Is it sitting at 110 in traffic but 90 on the motorway? - If so the fan thermoswitch is faulty and not working at both stages.. Also a good idea to change the temp senders Quote Share this post Link to post Share on other sites
