hotdog
VR6 High oil Usage
My vr6 engine appears to use quite alot of oil.
There appears to be no blue smoke during normal driving
If I floor it there appears to be black smoke in the higher gears
Engine has done about 77k no rattles :wink:
Have had a couple of leaks sorted recently rocker cover and sump gasget
It has just passed a mot no probs
So anybody help? or have any suggestions
Many thanks if you have any idears
Steve
Hi thanks for the replies I have had car serviced recently and think they have used a fully synthetic oil
Will have to check and get back to you
Steve
I have a vr6, i use semi synth, fully synth is too fine for my car and just goes out the exhaust
i would say the same problem is with your car, just the oil is too fine
Hi all and thanks for the replies
Looks like a semi synth oil was used but I don't know what type at the moment
Anybody got any recommendations?
Cheers
Steve
Steve
Vr6's will burn oil as normal.
When you say a lot, what do you mean? The C when New would typically burn circa 1ltr/1kmiles.
no worries
My C now burns around the same with 52k on her maybe a little less for some reason or another.
I Would be more concerned about the blue smoke. sign of a very tired engine, but as u say only in higher RPM would be of no great concern.
Maybe your mind playing tricks. If the engine was cold or with continuous blue smoke would be a sure sign of the bug bang.
Hope this is of interest. but define high oil usage.
no worries
Erm, I'd say that was very high usage, they only quote 1 ltr in the handbook to cover themselves...
Half to 1 litre every 3k's i'd say is normal...
My 108K VR uses about a litre over about 4000 miles. I had the head rebuilt and bores checked last year but mine's never particularly had a thirst for oil anyway. Some just seem to drink the stuff and others are more frugal with it. I use Quantum silver semi-synth oil although considering trying some slightly thicker 15/40W stuff next as the engine is getting old!
This is in my opinion , of course ! :wink:
But i would use "synta silver" semi sinth , this is used by most dealer's and the like
The best place to get this, would be Gsf or europart's ! :)
ahh right i have fully synth castrol gtx in mine and the oil temps get quite high sometimes as high as 120!! would that explain it the thin oil. whats the reccomended semi syn th. what weight. mine has just done 100k and with no mods but they r planned. it doesn't use an excessive amount of oil as it is tho!
Castrol GTX is mineral isn't it? I though their Magnatec is semi-synth and the 'R' is fully synth? Could be wrong tho !
A good weight for the VR is 10/40W or 15/40W... or if it's getting a little long in the tooth, 15/50W.
Hi and many thanks for the replies
After reading the above perhaps mine is normal I was just surprised when checking my oil level after a few of weeks I do about 200+ miles a week
As to how much I will have to check more regularly I suppose and how many miles etc
My old GTI hardly used any oil at all and I was surprised how much was being used
Cheers
Steve
