jamesmilsome
Rubbish MPG with lysholm fitted - any easy fixes
Hi,
Since fitting a Lysolm charger the other week my fuel economy is crap. It has not been over 24 MPG and is usually at 20. I'm not ramping it as I'm trying to run the charger in.
I know it probably needs setting up properly with the new charger but is there anything I can do before I go down this route.
cheers
have you calculated this figure or are you just reading this off of the mfa? as the mfa may no longer be accurate with your current set up as it were designed for a standard motor,,
Off the MFA but I got a 16 MPG today when nailing it.... Could it be this far off?
It also seems to over rev when I pull up at lights etc as if its still getting fuel delivered?
cheers
Could prob do with a Stage 5 chip and a tune but I want to save that until I get the engine checked over and a smaller pulley fitted, and maybe a FMIC, and bigger injectors, a 1.9 conversion, new wheels and tyres, new suspension.....
Bugger - How long till Christmas
