Coley17778
REVS STUCK
Pulled into car wash and stalled :oops:
on restart revs seem to stick at 2500
blip on throttle cured this
also noticed slight overun somtimes when changing gear
but this is totally random.
also does anyone recomend any garages in the county durham area north east cheers
Throttle cable?
have had it checked was going to replace but mechanic told me there was nowt wrong with it have replaced isv and temp sensor to no sucsess
make sure ure ISV is plugged in, the back of the Throttle body has the black plug in spot. if you are unplugged there then ure RPMS will stay high. just for good measure check ure injector seals.
