Rhodri
Porsche 911 front callipers?
I have a 95 model 2.0 16v. I want to put bigger calipers/discs on the front. I have got a set of 17's going on very soon. I am wondering if a set of 911 callipers will fit the front without changing the hubs to 5 stud (i have a brake specialist who will make me the discs in 4 stud)?
Also will i need to replace the wear sensors and shim discs?
I don't know if i am talking through my arse here guys.
Cheers Rhodri
Surely if anyone has the knowhow to make the discs for this conversion, they will be able to advise you on carriers and all aspects of the conversion?
If not I suggest you contact someone who does, such as:
http://www.badger5.co.uk/
what you need for the brake conversion is seat ibiza curpa r calliper carriers and disc's 305mm and porsche boxster s front callipers or 968 ones all this bolts to a mk2 16v hub ..if your corrado has the same hub then you can do it
