andycowuk 0 Posted February 6, 2005 [schild=11 fontcolor=000000 shadowcolor=C0C0C0 shieldshadow=1]cheers people [/schild] anyone running 9x16's? could i get away with running the following on standard ride height for now? front 9x16 et 25 rear 9x16 et 15 all with 205/40's. i know the rears will stick out 10mm more than the front,but both should have a nice dish 8) cheers,neil. Hi mate I do get occasional rubbing between the outer wall of the rear tyres and the lip on the inside of the arch. I have 7.5x16 et25 wheels, and 215/40/16 rubber. The suspension is Leda coilovers with 250lb rear springs, which is probably harder than any kit has. I am lowered at the rear by no more than 40mm. I think you will deffinately have problems at the back..... the std suspension might be a bit flappy to keep those wheels under control. HTH Quote Share this post Link to post Share on other sites
BigTartanJudge 0 Posted February 6, 2005 Hi, I used to have 9 x 16" ET15 Borbet B's all round on my rado with 205 40 R16 tyres all round. I was running full Koni adjustable suspension with lowered springs and I had rolled arches. I woul get rubbing quite a lot so I would recommend you get arches rolled and possibly extended professionally and defo. get coilovers as well. Should be ok with this, Cheers, BigEastSideVWG60 Quote Share this post Link to post Share on other sites
Riley 0 Posted February 6, 2005 thanks for the input guys,appreciated :D andycowuk ,your suspension must a cost a small fortune :shock: so no problems with the fronts then? in either 7.5 or 9x16... are there not many 9x16's in offsets more like 35 then? :oops: i know its only maybe 20mm difference but could help a lot! neil. Quote Share this post Link to post Share on other sites
