Tedb 0 Posted January 27, 2005 Can one of you knowledgeable Tech persons tell me where the Air Flow Meter is located on a 2.0 16v? Presumably above the Air Filter Housing somewhere, How does one identify it? In addition, can/should the ISV be cleaned and how should this be done? Mine seems to have a lot of carbon inside it. Both of these were suggested as potential sources of a High Idle Problem I have (intermittent) when car reaches full operating Temp. Cheers Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 27, 2005 Can one of you knowledgeable Tech persons tell me where the Air Flow Meter is located on a 2.0 16v? Presumably above the Air Filter Housing somewhere, How does one identify it? I think so - looks for the electrical connection to it... In addition, can/should the ISV be cleaned and how should this be done? Mine seems to have a lot of carbon inside it. Carb/Injector cleaner spray, just blast it! Quote Share this post Link to post Share on other sites
Tedb 0 Posted January 27, 2005 From checking recently there are a couple of sensors/lectrical connectors on the Air Filter Housing unit, left and right side but which is the Air Flow Meter? Thanks for the tip on cleaning the ISV. Quote Share this post Link to post Share on other sites
corradophil 3 Posted January 27, 2005 The airflow meter sits directly over the airfilter with the large round rubber connection to it!!! Also the high pressure fuel lines connect to it. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 27, 2005 Also the high pressure fuel lines connect to it. Good call - didn't realise that! Quote Share this post Link to post Share on other sites
