Riley 0 Posted January 31, 2005 right guys i tried the charger test through the mfa... at tickover i get anything from 540-560 fluctuating with idle. when i wound it up in 3rd,the highest i got was 1760. am i right in thinking the no. at idle is too high,what do i need to check out? what does the 1760 n0. mean? cheers for any suggestions guys. :D Quote Share this post Link to post Share on other sites
G-Lader 0 Posted January 31, 2005 someone will be along in a mo to correct me but 1760 at the top of third is about 12 or so psi so would indicate the charger is fine, i think i get appox that with a 68 and a fairly recently rebuilt charger. Id ignore the reading at idle.......... Quote Share this post Link to post Share on other sites
g60racing 0 Posted January 31, 2005 look here.. http://www.dubforce.net/forums/index.ph ... =1263&st=0 Quote Share this post Link to post Share on other sites
Riley 0 Posted January 31, 2005 cheers guys,so im getting around 11 psi. any ideas on the vac leak? :oops: cheers. Quote Share this post Link to post Share on other sites
