SteveM16v
Juddering when pulling
When pulling away I'm starting to get a judder. If I slowly bring the clutch up without using the accelerator its fine, it just seems to be when I apply some gas? The gearbox is sloppy and crunches when putting into fifth (unless I slam it in hard (as it were)), but I've had the car for over a year now and the box has always been the same.
I've recently had the clutch done - could it be that its not setup right?
Thanks as always
could be engine/gearbox mounts or a dodgy clutch fitment... :|
Crunching could be to do with the gear cable setup not being quite right... :|
