oldirtybastard
Corrado G60 Starting/ running problems
Hi peeps,
Im having problems with my 91J Corrado g60,
Its not starting up properly, the engine runs up and then it struggles to rev,
the chargers been rebuilt but ive checked the supercharger for leaks etc so im assuming it isnt that,
the engine starts up after hesitation then it struggles to rev, and makes a struggling noise, and also the oil light flashes and bleeps,
its just been to have its mot done, for which it required a bit of work, but no work for engine/emissions, but since its come back the oil lights been like that, i assumed it was ok as when i drove it back it was fine, I don't want to blame the garage unless its there fault which i think it my well be.
but today when i start it its all wrong.
any ideas what this mite be peeps,
thanks for any help given,
taz
sounds like the usual blue temp sender the oil light comes on when revs drop right down and the pump isnt running fast enough. swap the plugs around from the blua and black senders on the front of the head water outlet it should run better or your black one might be gone too! they are v cheap from vag as well!!
