eyebrowski
new to G60s...a few questions
with supporting mods (fuel, ic, exhuast, afc, intake) how much power is the stock SC good for?
how much HP can the stock bottom end handle?
how soon are bigger injectors and fuel pump needed?
where are aftermarket parts availible?
what weaknesses do the G60s have?
thank you.
-Greg
i have seen up to 280-300hp with stock botom
over 17-18 psi you be better changing injectors
For parts there are various companies in uk also germany.
The charger is something that should be taken care of as theengine in runs strong.
charger should be rebuilt every 45000 miles which i guess is close to every 60000 km for you metric boys?
check out http://www.ame-racing.de if you feel like reading german but if you sift through, these guys have their poop together
motor's fine, its just the gingerbread stuff that's a killer :D
An 8v G60 will get you up to 250hp, you have to spend a lot of money to go over that, ie cross flow head etc.
Weaknesses are the charger and fuel delivery. STock injectors max out after 15psi (16psi non-cam) and the Digi ECU doesnt help things with its infamous Digi-Lag.
