brian g60 corrado
cable change adjustment
The tools is a very complicated looking beast that only VAG dealers are likely to have.
Manual adjustment is possible using nothing more than a ring spanner and a little care.
Before starting to adjust anything though, make sure your gearbox mount is in good condition, that all the circlips at the gearlever end of the mechanism are present and correct, and carefully mark the existing positions of the cables on the gearbox end of the mechanism.
Next, what's not good with your existing gearshift?
have already fitted new clip on the gearstick and changed the box oil to gl5 80/w90.but just find it hard to get 1st and 2nd.mainly when cold.
also find the throw exesive,would adjustement improve this.
brian.
This maybe because the oil should be a 75w-90 - not sure how much difference the 5 will make but you'll notice it most with the current weather...
1st and 2nd are usually reluctant when cold, it's a trait of the 020 and 02A boxes. The 02M isn't much better either.
