pookyvr6 0 Posted February 26, 2005 Guys, Just tarting up the VR before selling the old gal. The only problem with the car is irregular temp readings on the console. Car does not overheat but will mostly show normal running temp and will occasionally drop down to around the 70 mark. I assume that this will be a faulty signal from the termostat. If I'm right, is the thermostat an easy DIY job? Alternatively, if anyone has any other suggestions as to what it may be, I'd be keen to hear diagnosis/repair suggestions. Thanks Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 26, 2005 The gauge gets its reading from the black temp sender, may be just that or the wiring to it.... Quote Share this post Link to post Share on other sites
