potatonet 0 Posted March 1, 2005 being that we all know that the bentley is very sketch on replacing the g60 water pump I was wondering if anyone had a good description of how to replace the water pump in my G60. just kinda wondering because its this weekends project. thanks. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 1, 2005 You need to take the alternator and charger off and the charger bracket, then its just the same as an 8v GTi Make sure you buy the whole pump not just the impeller and a new thermostat and plastic housing with O rings and some G12+ of course... Quote Share this post Link to post Share on other sites
g60bv 0 Posted March 1, 2005 i'm doing it at the moment, i'l try and get some photos. it's not a 5 min job thou. Quote Share this post Link to post Share on other sites
Mavryk750 0 Posted March 1, 2005 here is the "not so easy" way Quote Share this post Link to post Share on other sites
Banana Man 0 Posted March 1, 2005 Mavryk750, Do you really need air con in Canada :D Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 1, 2005 ..and use a proper oil filter!! Quote Share this post Link to post Share on other sites
Mavryk750 0 Posted March 1, 2005 Supercharged, I took the motor out before I had the chance to do an oil change, I have only put about 30km's since buying it, so... you can't blame me for the filter. lol Banana Man, I don't understand what you mean by "air con" sorry. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 1, 2005 Airconditioning Dude... and your weather... Quote Share this post Link to post Share on other sites
Mavryk750 0 Posted March 1, 2005 oh, I see, I am a bit tired. I am actually doing an A/C delete. It does get quite warm in the summer here, I think the high last year was up around 38 Deg. But I'll just pop the sunroof if I get too uncomfortable. Quote Share this post Link to post Share on other sites
potatonet 0 Posted March 3, 2005 supercharged who makes a proper oil filter, I have a WIX one right now the stealer told me to get one being that they cant order them. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 3, 2005 I just use the VAG Dealer ones with the hex on the bottom, it's the only one that I know is correct for that engine, don't use a standard Golf one... Quote Share this post Link to post Share on other sites
blackcat 0 Posted March 26, 2005 You need to take the alternator and charger off and the charger bracket, then its just the same as an 8v GTi Make sure you buy the whole pump not just the impeller and a new thermostat and plastic housing with O rings and some G12+ of course... Is this the same for 1.8 16v? Is it an easy job to do? Plus, forgive for being stupid but what is G12+? Quote Share this post Link to post Share on other sites
blackcat 0 Posted March 26, 2005 Ok now I'm going to be really stupid :wink: I've looked in golf haynes manual, it doesn't mention water pump, is coolant pump the same thing? Quote Share this post Link to post Share on other sites
Walesy 0 Posted March 26, 2005 forgive for being stupid but what is G12+? ?? yeah Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 26, 2005 Yep, the coolant pump is the water pump (bloody haynes!) Black Cat - not sure what the 16V water pump is like, probably the same or very similar, at least you havn't got a fecking great supercharger to get out the way first in order to get to it! G12+ is VW's own coolant additive (it has replaced the G11 and G12 that our cars had when they were built) It's about a fiver for a 1.5 litre bottle, you'll need 2 of these as you want a 30-40% mix (with distilled water) - 4 cylinder cars have a cooling system capacity of about 5-6 litres, The VR6 has nearly 10 litres. Quote Share this post Link to post Share on other sites
blackcat 0 Posted March 26, 2005 Ta very much, Supercharged, I'll follow the instructions in golf haynes, I assume the 16v golf is the same. Do I have to get the G12+ stuff from VW or can I get it from GSF? Quote Share this post Link to post Share on other sites
