golfg60 0 Posted March 1, 2005 Hi chaps, Just wondered if anybody can help with a strange noise i get. When im driving at any speed and dropthe clutch when i engage it again i get a knocking noise. It also happens when i change gear and engage the clutch. It sounds like there is some excessive play in the drivetrain somewhere but i don't know where to start looking. Any ideas anybody....please Tom Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted March 1, 2005 Try the engine mountings as a first guess - especially the front one. Test it by lifting the bonnet, putting on the handbrake hard, engaging first gear and gradually letting the clutch in - if the front of the engine moves very much, your front mount is bu@@ered. It's a very common problem and quite easily fixed. Best wishes RB Quote Share this post Link to post Share on other sites
golfg60 0 Posted March 1, 2005 Cheers pal! I should have said, i had the mounts replaced last week which did sort a few other problems out but not this one. Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted March 1, 2005 OK, maybe a cv joint, especially an inner one, I have known bolts to work loose. Or maybe loose wheel bolts............ Quote Share this post Link to post Share on other sites
golfg60 0 Posted March 1, 2005 Yeah, could be mate, i'll check the wheel bolts now. How do i check for a cv joint? Quote Share this post Link to post Share on other sites
Roger Blassberg 0 Posted March 1, 2005 You need a spline tool of the correct size - it's like an Allen key, but has 12 points. You can buy a set of them to fit into a 10mm socket from Halfords etc (do not use a hexagonal Allen key or you will damage the recess in the bolt head). There are 6 bolts per cv joint where they bolt onto the output flange of the diff. Check that they are all fully tightened. If it's not that, maybe there is a broken bush somewhere in the suspension or an anti-roll bar drop link may have given up the unequal struggle. Best wishes RB Best wishes RB Quote Share this post Link to post Share on other sites
golfg60 0 Posted March 1, 2005 Thanks for that info Roger, you've been a great help mate. I'll check those tonight... Quote Share this post Link to post Share on other sites
