kerrinmay 0 Posted March 8, 2005 Should the front discs on my 2.0 16v be ventilated? Reading various publications seem to imply that they should be, but they are not. Has a previous owner had the wrong ones fitted? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 8, 2005 All Corrado front discs are ventilated. Don't confuse vented with drilled and grooved. Vented just means two discs stuck together to form an airspace between the two for cooling. I'd be VERY surprised if you have solid discs on the front. Quote Share this post Link to post Share on other sites
kerrinmay 0 Posted March 8, 2005 All Corrado front discs are ventilated. Don't confuse vented with drilled and grooved. Vented just means two discs stuck together to form an airspace between the two for cooling. I'd be VERY surprised if you have solid discs on the front. Thanks. Think I was confused with drilled and grooved! :oops: Quote Share this post Link to post Share on other sites
