LowG 0 Posted June 22, 2003 I was puting my big intercooler in the front of the car and the power steering cooling pipe was on the way so i had to cut it a bit on the side in order to move it back. I did all the cuting and clmaped everything,reflushed the pwstering liquid with new,turn the car on and steering feels hard,i checked if i had siezed the tube somewhere but still no joy. When flushing the old liquid i turned the car for a few seconds in order to get all the liquid out so the pump was runing empty,is it possible that i burned the pump? it dosent make any noises at all though so im kinda confused. Any tips to where the problem might be is much appreciated and boy that front intercooler makes a difference i can tell you,the boost build up is so quick as teh piping is much shorter and with fewer bends. rgds miguel g60 Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 23, 2003 Did you turn the steering lock-to-lock a few times when you primed the system with new fluid? Kev Quote Share this post Link to post Share on other sites
LowG 0 Posted June 23, 2003 yes i did,it was ok for a while and when i turned the car on after few hours the problem was still there,turned lock to lock about 40 times but still no joy :x Quote Share this post Link to post Share on other sites
