m1cah 0 Posted March 16, 2005 Is there any difference between a 2.0 16v servo and the one on the VR6, basically will it fit the VR6? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 16, 2005 AFAIK all the ABS equipped Corrados (Brake pedal position sensor in servo) use the same one. It's the Master Cylinders that vary, G60 is 22mm, VR6 is 23mm and I think the 2.0 16V will be 22mm aswell. Quote Share this post Link to post Share on other sites
g60bv 0 Posted March 16, 2005 so would a 23mm vr6 one fit a g60 servo.?? i've always wanted in your face brakes. you only got to look at the brack pedel in the mk5 and you shoot through the window,! awsome. Quote Share this post Link to post Share on other sites
