Dennis.be
switch an ATB gearbox with an AGC
Since a couple of weeks has the C a ratle somewhere around the flywheel or gearbox, I'm afraid that the gearbox is coming to an end.
I've got a 16v (AGC build from 04/89 till 07/90) gearbox in the garage, can I place this one in stead of an G60 (ATB build from 09/88 tiill 07/90)?
The 16v box is shorter than the G60 one, the only negative thing on the AGC box is that the topspeed is much lower than the ATB box.
Does some of you have some experience with this modification? The most important thing is that the main shaft is the same as the ATB box.
