Codo93g60
i'm new
Ok, i have 2 questions. first, what is the easiest way to get more power, and when I bought the corrado it don't run! it was running when he had it. he did some work on it, still ran, but stopped running. Anyone know whats wrong?
some more info would be good, like whst did the other guy "work on" does it crank/turnover?
welcome to the forum by the way
93 g60, good car, when they went digital on G60's. post something like, it cranks but it doesnt fire, does it even crank? more infomation would be nice.
take a spark plug out and place it connected on the engine block, if you can have someone start the car you can see if it sparks. also see if your injectors are putting out fuel by removing a different spark plug to see if it is wet after trying to start. my car did this, had spark and fuel, fuel was at full spray, ECU fried.
yes it cranks but it is a 92, i have thoughts about the fuel pump??
Do you hear the pump prime when you turn the ignition on, Also check the wiring to the Hall Sender (distributer)
