Hans G60.nl 0 Posted June 29, 2003 You all know them i suppose, the shift light which comes with the big rev. counters, i don't really like a big rev. counter for a corrado, but i do really want a shift light.. this is the idea: there are places left in the dashboard for led's, just beneath the rev. counter... i want to put in 2 lights there, 1 for maximum torque, 1 for the maximum revs to shift at the right moment.. at the second led i want to connect a buzzer.. now i only have 1 problem left: how do i build a print for this ? like, what components would i need, how should i build a print (or let build if it's a difficult one, i can't make a real print myself, just pin on with the prints with holes in them) etc. etc. any ideas ? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 29, 2003 I guess you'd need some kind of logarithmic counter chip, such as the LM3914,3915 & 3916 series. These chips count events (such as hall sender pulses for instance) and can be made to do certain things against certain parameters, like displaying a grid of LEDs etc etc. You could just buy a tacho kit and take the circuit board out and run fly leads off the LED outputs and mount your own bulbs as you wish? Kev Quote Share this post Link to post Share on other sites
Hans G60.nl 0 Posted June 29, 2003 i think the tacho kit is a bit simpler to do... then 2 bright led's and a buzzer connected... BOOOAAARRRRRRRRRRRRRRRRRRRRRRRRRRRR flash BOOAAARRR beeeepppp ;) Quote Share this post Link to post Share on other sites
G60Jet 1 Posted June 29, 2003 Autometer do a shift light the same as the ones that bolt onto there rev counters maybe easier to sort one of them Quote Share this post Link to post Share on other sites
mambomonkey 0 Posted June 30, 2003 Go to http://www.summitracing.com, and look up shift lights. There's a company called proform i think which do seperate shift lights. You simply dial in the revs on the back without any need for rpm pills e.t.c. I think they are only 40 odd dollars. Not as neat as your idea but easier???? :) Quote Share this post Link to post Share on other sites
Hans G60.nl 0 Posted June 30, 2003 i don't know if you know the CONRAD business, well know in the netherlands and germany,.... i have seen a little print with the components on their site.. Quote Share this post Link to post Share on other sites
