2cc
Steering Rack Compatibility
Apologies for asking, I tried the search but at my age will probably die before I can read all the results that came back :)
Question is: will a rack from a '90/91 G60 be identical with the one in my '90 16V?
I have a suspicion I've read somewhere they have slightly different ratios so don't want to buy something that ain't a straight swap. Also, I have no idea what the part no is on mine, and sadly am not in a position to check it in near future either.
I'm sure that someone here will know the answer straight off so thanks in advance.
Rats. Just had as look at the list but it only shows s'rack for the VR so still don't know.
Anyone?
Carefull mate,
I had the same problem with
my rack,'90 models have more spleens
on the input shaft compared to '91 onwards
racks,later types have 22 splines were's '89/'90
ones had 36 splines.The two aren't interchangable
because you'd have to also change the two UJs that connect
the rack to the steering colum,only 320euros from stealer...
Ah cheers veedubbed I just had a feeling in my water that there was something different about the gearing. I'll still try to find definitive answer and post result if I get one.
