moneypit
wiring on the vr6
Hello all, recently purchased a 93 corrado vr6 with some electrical problems. i need to see what order the wires go for the following,
intake air temp
Lamba sensor
camshaft positioning sensor
I have replaced the the coil pack it is now running ok, but the above have been damaged.
Any help I would be very grateful :lol:
moneypit, not sure that I understand you question. What is you want to know and I'll see if I can help?
thanks for the reply,
the problem is when i bought the car for a tdy sum of 500 pounds, i thought i coulod fix it all myself, but its been one thing after another. I finally got it running after fitting a new coil pack, but on closer inspection the wire to the camshaft positioning sesor, air intake sensor and the lamba sensor have all been cut at some point and bodged back together!! withoutb the proper plugs on the end, so i need to find which order these wires go .
As i do not have wiring diagram i thought if i nhad picture of them it would be very helpful.
any input would be very grateful :D
